Half Victoria Half Lilith Question
in New Users
Hi guys how do you make a figure look like a mixture of two charcter presets like for example 50% Victoria and 50% Lilith or 60% Victoria and 40% Lilith, etc.
Go to the shaping tab, select the shaping morph for the characters, and dial in the value you want.
For the shaping tab, I recommend you take a look at the video training, point 5: http://www.daz3d.com/help/help-daz-3d-video-tutorials
Hi so I have to click the character of Victoria first then click the character of Lilith then adjust it on he shaping tab? Won't it add Lilith as a separate character resulting in 2 characters instead of a merged one character? Thanks for replying by the way :)
You don't need to click either character. Just load in the base figure (whichever Genesis you're using), then dial up the characters you want, in the proportion you want, in the Shaping tab (or the Parameters tab - either one works).
No, the only way to add a new character to the scene is to load one from Smart Content or the Content Library
Laurie
Loading the base figure and then going to Parameter or Shaping and dialing it in will provide the shape, but not the skin/textures. Loading from Content will do both at the same time.
Hi can you kindly elaborate? Like when you mean base figure is that the Genesis 3 without any character style figure?
Does this answer your question?
Or you could load one of them, whichever texture set you wish (the mixing is for the shapes, not easily for the materials), and then adjust the shaping settings on that.
