M.A.G.2 Robotic Arm on Genesis 3 Female
Does the arm work well with G3F? I'm not sure how geografting crosses over generations.
  • GeoGrafting as such doesn't convert - it is critically dependent on the placement and number of vertices in the emshto which it attaches.
    edited October 2016
    As Mr. Kitty says, it won't work on G3 without workup because it's a geograft for G2.  You'd have to paint three transmaps (left, right, and both arms) to hide the arm because just hiding the bones/body parts will leave a big ugly gap in the collarbone area, and most people aren't able/willing to do that.
    Although give me a minute here and I'll see how long that takes me.  We're not doing a Genesis 3 one (unless Antfarm does it solo, and he certainly has my blessing, he's a great rigger now!) so other people might want to try this.
    Post edited by SickleYield on
    Oh, wait, I'd forgotten.
    You can't use a trans map to hide geometry on Genesis 3.  The makers of Iray won't have the shader allow transmission when the cutout opacity is in use.  So if I tried to do a freebie for that it would just break the skin shaders. :(
  • Well, that's both understandable and sucky! I'm glad I asked, though.
  • mtl1mtl1 Posts: 1,508
    Wouldn't assigning a new surface to certain polys and making them transparent work too? :)
    If the border of the arm lined up exactly with those polygons, yes.  On G3F it does not.
