Nudity in the Forums - What is allowed?
What I have is a bare model with textures added and tweaked in Carrara to make the G2F figure appear like a Statue with a somewhat stone or marble look. At the moment it's head is bare... I'll add hair only and shade the same as the statue when done. The pose I'm using is sorta like some statues I've seen. Now to the questions.
- Are the rules in the forum regarding nudity the same as DAZ content promos? See all the promos for Sculptural Genesis Ultra Fun Kit? I wouldn't purchase any product similar if it could not be posted in the forums.
- Would I need to cover certain areas with anything? If so what areas? I could add pasties like sea shells or leaves to 3 frontal areas but what about the backside/buttocks?
- I've read the TOS. Does nudity apply to a statue?
I do know better than to post anything lude, obscene or with pubic area detail and would never post a figure with realistic skin which is nude. After all they would have a bit of clothing in key areas.
I've already 2 test renders of the statue posted. If they are not allowed I'll remove them ASAP and replace them with a wireframe or close up which will conform to TOS. I asked if it was allowed but nobody replied one way or the other.
Thanks in advance for any help and opinions about this.
If it is skin then it is nudity, if it is obviously meant to be stone, porcelain, metal, plastic then it will probably be allowed.
Thanks... now I can relax.
