Two Nvidia Cards
mcorrmcorr Posts: 1,104
edited October 2016 in The Commons
I'm not sure about the answer to these questions.
If I have two GTX nVidia cards, a 750ti that my monitor is attached to (630 cudas, 2 GB) and an additional 760ti on the motherboard (1320 cudas, 2GB), what will happen with the cudas and GPU RAM?
(a) Will DAZ Studin (i,e iRay rendering) use all the cudas on the 750 and 760, or only those on the 760ti.
(b) What about the GPU Ram? Will it all go to DAZ Studio (for holding scenes in Ram), or will DAZ Studio only use the 760ti Ram for loading scenes?
(c) Finally, I am wondering about this. I now only have the 760ti, so it drives the monitor and also does all the iRay computations (rendering). If I set up my rig as explained above (add a 750ti for only the monitor, and then add a 760ti on the motherboard for rendering), will the screen refresh (for example, turning objects in iRay interactive mode) slowdown, remain the same or get better?
Thanks in advance for your clarifications!
Post edited by mcorr on
  • Charlie JudgeCharlie Judge Posts: 13,253
    The VRAM is not additive. The whole scene will attempt to load to both cards; so, if your scene is greater than 2GB, all rendering will default to your CPU.
    Assuming your scene is less than 2GB, all the cuda cores iof both cards will be used in processing. So, effectively you will have just slightly less than 1950 effective cuda cores.
  • mcorrmcorr Posts: 1,104
    That's interesting and really helpful (thanks!)... so all the cudas become available, but only if the whole scene fits into the VRAM?
    And just to be sure, the vram that is sought out, or used, is the one with the highest number of GB?
  • BeeMKayBeeMKay Posts: 7,019
    You might find this interesting: https://helpdaz.zendesk.com/hc/en-us/articles/207530513-System-Recommendations-for-DAZ-Studio-4
    Itay will try to fit the scene into each card separately, that means that if your scene is 1.8GB (That is a dressed and haired Genesis with a very basic background...), and the card that runds the monitot just has 1.6GB free VRAM, the monitor-card is out, and only the non-monitor card with the full 2GB available is "used".
    If your scene is 2.1GB, both cards are aout, and the render will go back to CPU, adding the full 2.1GB to your RAM.
    got it ...thanks!
    How about the part (C) of my questions? What will happen to the screen refresh?
    Then, of course, you will also only have the processing power of the cuda cores in that one card. And, I'm not sure, but it may have to be set manually to only use the card with the most VRAM.
    Got it ... Thanks!
    edited October 2016
    How can I find out the amount of RAM a scene takes up? If I know this, I can minimize the size of a scene until everything can be held in available vram (and therefore, render faster).
    The expensive version: http://www.daz3d.com/iray-memory-assistant
    The "best guess" version would be, start your task manager. Load DS. Note down how much memory is consumed. Create your scene. Look at Task manager again, take note of new numbers. Substract first reading. That will give you a very rough guess to the size of your scene. But like with the memory assiastant, there are always additional factors playing into it, like normal maps and other factors, which consume more memory in render than the mere size of them.
    As for your C question, That would fully depend on the size of your scene. As long as it fits on both cards, two cards are faster than one card (more CUDA cores). But from my own experience (having rendered with a GTX 660 2GB card for a year), 2GB is not a lot in any case for Iray, and you'll really have to shuffle around a long to fit things on the card, unless you want to render Vicky in her Temple with a sword.
    edited October 2016
    This utility may be of help: http://www.daz3d.com/iray-memory-assistant
    That said, only very basic scenes will fit on a 2GB card and 4GB VRAM card is often considered a minimum for practical DAZ Iray use. I have a 4GB card and really wish I had opted for more VRAM.
    Post edited by Charlie Judge on
    edited October 2016
    Thank you all for the really useful information and advice. I now know how to proceed.
    BTW (just for the record) ... it's not a 760ti that I already have, but a 660ti .... and the 750ti is the one I am thinking about buying. It's an extra 620 (or something) cudas, which should help noticeably with rendering times, but ... the vram limitation will remain a problem if I only buy the 750ti.
    At the moment, I would be happy even if I could only speed up rendering of the initial basics (setting up the skin, posing the character and getting the lighting right ... all of which would--I think--fit into 2GB). Just being able to do that would be well worth an extra 100 bucks since I spend so much time in that initial phase of the creation process (where you are endless tweaking the lights, background hdri, etc.). How long it then takes to render the whole finished scene that doesn't fit into vram (character with clothes, background, props, etc.) is of less concern to me: I just hit render and go eat something, or surf the internet until things are done.
    That having been said, if I can find an older and inexpensive 4GB nVidia card (not the newer 1xxx ones, but one that will run on my present rig), then I'll go for that. That'll be worth another 100 bucks. Then when all the presently new iray-geared software, hardware, drivers, etc. are stable and their costs come down, I'll just buy a whole new rig (CPU, etc.) with the best graphics card(s) I can afford.
    https://www.amazon.com/EVGA-GeForce-Quieter-Graphics-04G-P4-2974-KR/dp/B00NVODXR4
    Refurbished, you can get it at $179, used starting from 210. It's worth the thought if you intend to spend 200 on additional cards anyway.
    Something to consider...is your power supply able to handle it?
  • bad4ubad4u Posts: 684
    edited October 2016
    The brandnew GTX1050Ti with Pascal architecture are starting around $160 for 4GB models, only need about 75W and GTX1050 usually don't need additional power supply cable attached. The Ti version has 768 cuda cores, and if you plan to go for a new rig some day, it even might be worth to keep that one for running the monitor then and use the larger card(s) for iray exclusively. The even cheaper non-Ti version only has 2GB, so only the Ti is worth considering, at least you are not investing in older technology, I'd say. Maybe read some tests.
    Post edited by bad4u on
  • MattymanxMattymanx Posts: 6,996
    Consider having two identical cards, even by the same manufacturer.  Also make sure you register your cards.  EVGA has a good reputation for warrenties.  Zotac is good too.
  • jardinejardine Posts: 1,215
    thanks for the reminder, mattymanx!
    j
