Spyglass
nelsonsmith
Does anyone know if there is a spyglass in the Daz store under some other name, or included in some bundle which I'm not aware of? I'm in a nautical mood.
Post edited by nelsonsmith on
There is this:
http://www.daz3d.com/surveillance-gear
I don't own it but if the spyglass/telescope is dismountable from it's stand it should be near what you are looking for. Also it has a set of binoculars.
http://www.sharecg.com/v/75518/browse/11/Poser/SpyGlass-V4-M4
and my favorite:
http://www.daz3d.com/little-sailors-props-and-clothing
http://www.daz3d.com/rosemill-astrometry
There's also one here as part of the sextant, but it looks to be detatchable. If it's not part of the sextant, I have no idea what it's doing there since there's no spyglass listed in the contents. Maybe someone that has it or the vendor can chime in? It's in every single promo image. Not sure what it would be doing there if it weren't actually IN the pkg.
Laurie
Hmmm, I own that package, I'll have to see when I get off work.
That one's in my cart now. The sextant is has that small spyglass so the navigator can see and orient direction more precisely of a distant object so I doubt it's detachable. The bigger one is more like they'd use for searching for sandbars and other obsticles in making sure all is clear.
The sextant and the spyglass are seperate props. The spyglass however does not collapse, but it's still a gorgeous prop.
Also one in this set: http://www.daz3d.com/nautical-bric-a-brac
ETA freebies:
https://www.renderosity.com/mod/freestuff/?item_id=65036
https://www.renderosity.com/mod/freestuff/?item_id=61208
I'm pretty sure that there is a spyglass somewhere in the Mage Tower props in the PC. A telescope at any rate. And there's a good chance that searching for 'pirate' in the store may turn something up, as well. Either as a separate prop in a prop pack or as an accessory to an outfit.
It's in the furnishings...and it's a stand mounted telescope.
http://www.daz3d.com/sorcerous-furnishings
There's also one in this pack...
http://www.daz3d.com/pirate-prop-set
The sorcerous furnishings is a texture pack for this one:
http://www.daz3d.com/mage-tower-accessory-pack-1
A "Binoculars" comes with this http://www.daz3d.com/post-apocalyptic-guard-tower
and here with poses http://www.daz3d.com/detective-poses-and-props
Yep, I put up the wrong one...thanks.
How did I miss that awesome set of props! Thank you for telling us about them!
Oh your right, I totally forgot to add in the Spyglass in the included items! I will ask for that to be added :)
It's really a very pretty one. If I needed a telescope/spyglass, that would be the one I would go to. :D
Laurie
I agree.
