Render just the wireframe??
I know that is probably not possible but is there any way to render just the wireframe of any model? I just need it for an effect that I'm trying to get!
It's possible, althrough indirectly.
In the model room, generate the UV map for the material and use it as a diffuse and/or alpha map in the shader room..
ok, sorry to be a pain but can you explain it a little more - i'm a bit of a newbie and I don't fully understand what you mean!
I'm at work and I can't access Carrara, so, I'm afraid I won't be able to provide screen shots before tomorrow.
BTW, what model do you want to render in wireframe. Sometime, UVMap are provided.
Im just messing with it using a cube and learning how to render it as a wireframe.Nothing complicated, I guess!
Regards
Ravi
Goto Renderroom -> select Renderer: Draft -> select wireframe -> do your render...
LOL, Holy shit, I've never seen that option!
Thank you so much!
