Mac64-bit Install Manager
Hello, any ideas where I can find the Mac64-bit Install Manager? All I seem to be downloading is the 32-bit which isn't compatable (or at least keeps giving me fatal abort now errors) with my Mac Pro. Thanks.
MacOS10.10.5 Daz Studio 4.9.2.70 (64-bit)
  • EsemwyEsemwy Posts: 578
    The 32-bit DIM is the only one there is. Are you sure you're not getting “[App name] can’t be opened because it is from an unidentified developer”
    https://support.apple.com/en-us/HT202491
  • Eh, that's annoying. No, this is in mid-install, not the Apple gatekeeper warning. Doesn't give me the opportunity to do anything other than abort.
    648 x 408 - 56K
  • Ok, forgot I can also download products in-app, so I'll go for that instead. Thanks for the response.
    Ok, that is strange. The current version can be downloaded as a zip, then you just drag and drop the unzipped application into /Applications.
  • fixmypcmikefixmypcmike Posts: 19,702
    Looks like a permissions issue.
  • TotteTotte Posts: 14,787
    Did you run the BitRock DIM installer from an account that "can admin the computer", i.e  can sudo and get the Authenticate Dialog?
