Duplicate formula message after creating a morph
ModernWizard
WARNING: fileinput\dzassetdaz.cpp(5486): Duplicate formula found linking xEnd & Value in /data/DAZ%203D/Genesis%202/Female/Morphs/D3D%20Gen%20X/Genesis%203%20Female/JarethAllG3F-10-14-2016.dsf.
Hi, I just created a single morph from many and moved it from G3F to G2F with GenX2. Now, whenever I load G2F, I'm getting a duplicate formula popup and information like the above in the log file. Any insight into what's going on and how I can fix it?
--MW
No idea how to fix this but I also have a character that triggers this type of error message. I click ok and the file continues to open OK with no further problems.
You probably have duplicate files in different folders. This is particularly common with GenX2. One clue: If the morph has a (2) beside it in the parameters, it's being loaded twice. This can also be a problem because it can cause the morph to have twice the strength than you intended.
