Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Misty, in that video I link to above, I know it uses V4 as the main subject, but I talk about some of these important ideas about what certain channels are responsible for, for any sort of material.
I haven't read that article you've found of mine from Carrara Cafe for some time now, but that might also go into a lot of that stuff too.
Cool!
Cool to know Phil, thanks for testing and sharing!
I am just trying the case that did not work - it must have been user error, because it is working now! Isn't Carrara wonderful. I may well post the results on my YouTube channel.
is exciting!! catching the carrara fever again.
kjlkj
Waay Cool.. TIP of the DAY - DesertDude
When PhilW speaks... one should listen. I always set gamma correction to 2.2 ... need to watch Realism Rendering videos again and again.
does all the light types give inderict lighting?
or only the sun?
confused cause it's under sunlight in the render tab
It's there because the Sunlight in the Render Room is actually Global Illumination, and doesn't require a "Sun" light at all. For example, a gradient, or even just a solid color background of anything brighter than black will provide global illumination when the Skylight is checked in the render room. Many people like to use a simple spherical map as global illumination, just like an HRDI. The difference in an HDRI is, well by definition, its High Dynamic Range, which allows its values to exceed 255 (unlike an 8 bit image), where values that do so will behave as a light source - even though the whole spherical background - any parts that are above "0" or black - will contribute to the global illumination.
Speaking of contributing:
When it comes to Indirect Light, any light will contribute as any sort of light, not just indirect. It is the surfaces in the scene which will use the lights to contribute to IL, depending upon their shader.
Also, Shaders will contribute to both IL and GI, and will actually act as a light source if their glow channel values exceed 100.
Of course, glowing shaders will always contribute to GI and/or IL.
GI doe NOT require IL, not does IL require GI - evn though both, together create a very realistic result.
For really great descriptions and instructions on all of this, I so totally recommend "Realism Rendering" via Infinite Skills, by Phil Wilkes.
is not only an incomplete sentence, but is also inaccurate.
It's there (I think - nobody really knows except for the devs that grouped it there) because it's part of this whole portion of advanced lighting via the scene, which doesn't require any 'lights', but lights will contribute to the result.
IL - Ambient Occlusion Only requires that we use the "Ambient" value or color in the scene's Ambient tab.
That stuff is also covered well in the Realism Rendering course.
thanks, rendering an aspen tree under full idl vs ambient only
all the leaves give good example
was the plane primitive size there the whole time???
never noticed it
followed a link to detroitchopshop loops and samples
sonycreative site redirected me to magix
Thanks for spotting that, never noticed myself! Quickly testing, it's there for most of the primitves, excluding Infinite Plane and Splat. Now if I can remember it's there, it will save a couple of clicks when I insert a plane and don't have to go to the Motion Tab to resize.
Yeah... I don't recall when I've first noticed it either. I did, however, notice that for some things, it doesn't entirley jive with the size metioned in the Motion Tab - kinda funny!
Agh! You're right. Bummer...
i'se confused by scaling terrains between the magnitudes. it disappears on me.
installing the Neon Lights set. has a textures folder under presets
oops
should name the signage levitating inn
with ambient light cranked up, cans set the direction of occlusion shadow? is it related to sun or camera?
with realistic sky and a sunlight only, can 100% turn off haze?
Ambient Occlusion shadows aren't really directional, they are determined by how "exposed" any given point is, so the sun or camera should not affect them at all.
I don't think you can turn off the haze altogether with a realistic sky, because that would be unrealistic.
Wonder what seasonal pic Miisty will add next... now her sig has an nervous/scared pumkin also hmm... next a frightened witch??
was a bit confusing. in the poser7, the ibl light position directed the ao shadow, i kept it close to the point light casting shadow.
trying some anything glows on halloween decorations.
holes in my plot niggling me. sending characters on a side quest, before the main story starts. scene inventory, planet, space station, and what else, an ancient ruin. they questing for a piece of the original chains that bound prometheus. we all know hercules and xena freed prometheus lol. chains were forged by hephestus, they must still exist somewhere.
kitbashing elfmages.
question is, would luggage go up in the elevator to orbit
certainly not traditional luggage but there might be clothes where they are going and what they have on... prolly something where they are headed... so no tooth brush or paste... wouldn't need much luggage at all... everything vac packed.
seen the thing they use to clean their teeth on Farscapes? lol
seeing if this will help with animating if nothing else should make me think of animation related things havent thought of
A classic animation reference! You can find a lot of Muybridge material online too.
book has a roo
watchin the walk cycle tutt video, really helped to de-mystify the graph editor, the bezier tweener.
ik link tool
anything besides flattening in graph editor?
I find that the Graph Editor can be useful when you see something weird happening, it can help pinpoint exactly what, then you can drag key points to correct it.
Another use is to adapt an existing animation (a walk for example) for the height of heels. Let's say the original animation was done assuming no shoes and then you put high heels on the character. You need to keep the motion in the ankles but add/subtract an amount to account for the slope of the heel. You can go into the graph editor for the heel rotation and drag the x-rotation keys uniformly (I think it is the x-rotation from memory, but it will be easy to see if that is wrong!) to add a consistent correction value - and you are done!
saw how easy it was to make a basic walk into an old man shuffle.
didnt touch on how to work on morphs with the graph editor
think i found the screenmarker
