Dynamic Clothing Control
I use a Mac. Why are not all the four functions
Did you install the Dynamic Clothing Control plug-in after you isntalled DS - installing DS always reverts the plug-in to the basic version, you must wait until the application has installed before you install that plug-in (and it's a good diea to do it with all plug-ins).
Which version of DS, I know I have gotten it to run but you need to follow Richards advice as if you update DS. Also, sometimes the basic plugin is still there and the adcanced is installed beside it , but I can give it a try now (haven't played with ifor a while... I'll be back...
Works in 4.9. 2.70
But be sure to remove these files from /Applications/DAZ 3D/DAZStudio4 64-bit/plugins
install_dynamic_clothing_basic.dzime
libdzoptitexclothbasic.dylib
libdzoptitexclothbasic.dylib.basic
Then start DS again.
