Glute Control for Genesis 3 (Commercial)
124»
  • cosmo71cosmo71 Posts: 3,609
    Forgot to write: Have also used your shape shift abdomen width morph at 20%
    Zev0 said:
    These have to be jcm triggered.
    stupid question, that means for me?
  • Zev0Zev0 Posts: 7,122
    The corrections have to be jcm's linked morphs to rotation and bend movement of the arms.
    well with jcm it is not possible to trigger that, have tried it. there is a need for morphs for the shoulder to adjust the inside of the upper arms and the sides of the torso underneath the armpit (axilla) and I mean the complete side not just the back (lats) and front (breast) the complete chest side has a need of an adjustment.
    edited October 2016
    It can be automated if you link specific morphs to trigger only with specific shapes.
    Post edited by Zev0 on
    edited October 2016
    the problem is, that it is not possible to move the arms apart from the torso without widen the side of the chest so the shoulder width morphs do not really help (the help just a bit)
    UPDATE: Sorry it is possible, x trans of the shoulder, have just to look if it has any bad influence of poses and the mesh and clothes.
    Post edited by cosmo71 on
    edited October 2016
    JCM for arm bend can affect and change torso as well. Doesn't have to be limited to just the arm. So you can be quite flexible in terms of the results you want.
    seams to work good, have moved both arms apart the body via x trans 0.5 and -0.5 and have done the same with the thighs (had a problem also with the crotch region when legs moved inwards)
  • MasterstrokeMasterstroke Posts: 2,312
    I think anyway, that G3figures' shoulders look small. I usuall use the shoulder width morph up to 30%. You won't hardley see it in T-stance, but with the arms down it looks much better. Not shure, but it might help with the armsChest intersection problem too. Never took a close look at it. ;-)
  • I purchased this but the morph dials aren't appearing for any of my G3F figures in existing and new scenes.  Tried uninstalling / reinstalling the package, not sure what I need to do.
    Hi. Where are you looking for the morphs?
  • edited January 2019
    Good morning!
    I looked under the "Shaping" tab for Lilith 7 and the base Genesis 3 Female.  I also looked in my content library but the only morphs there are to zero the glutes.  I tried applying the Puppeteer preset but that didn't load the morphs either (under the Shaping tab) and the control looked unusual (it had no arrow buttons), but I've don't use Puppeteer so I may just be seeing it wrong.
    Post edited by christopher-2607496 on
    edited January 2019
    They are all under the figures Pose Control/Hip/Glute Control.
  • I see them - thank you so much!
    You're welcome:)
    Hi Guys there was an update. Please Ignore this..There was an issue by not removing the shapes folder..I will let you know when correct one is live. Thanks.
