Map issues
Mynyori
A while back I bought Creature Creation Pack and the fantasy maps that go with them, though it no longer exists. The pack loads up, but the maps don't. When I try to access them, they can be viewed as images only. How can I load them in DAZ so I can use the pack to its full potential?
You need to go to the Surfaces pane (Window>Panes(Tabs)>Surfaces, if it isn't already open), with the model selected, select the surfaces of the model, and apply the maps as needed (the main one will be Diffuse/Base colour, there may be others in the pack) by clicking the little square icon to the left of the colour bar and selecting browse from the menu. Once you have the maps applied you will need to experiment with the other settings.
I'll try that. Thanks.
