Lose weight now. Ask me how. Wait... don't ask me, tell me.
ghastlycomicghastlycomic Posts: 2,531
So, I'm experimenting with rigging and weight maps and I have a question about erasing weight maps.
I've got a little overspray happening with some of my weight maps, how do I erase it from areas. I see a paint brush and a smooth brush, but no eraser.
  • Richard HaseltineRichard Haseltine Posts: 108,456
    Hold down the Alt(Win)/Opt(Mac) key - you can see, and adjust, the shortcuts in the Customise dialogue - Window>Workspace>Customise in 4.5.
    sometimes it need , fist coloared more with weight map,, to delete the weight ,,
    1 more coloerd with holding "ctrl" key ,(soft coloer ,,I think)
    the area where you want to delete,
    2 then use "alt" key holding , use brush tools then delete the area.
    or I sometimes
    1 select the poligons , (need change tools to poligon group editor first,,) by rasso or drug mode.
    then return to weight map tool.
    right click on the 3d window, then " fill the selected faces" by "weight 0 %"
    after that,, delete the coloerd area (around border may still keep some weight)
    by "ctrl" and " alt" to adjust.
    if you need check,,right click ,3d view, then change weight display mode,, "weight veritces"
    it tell you where you remain the weight more clear. I often coler weight ,, another area ^^;
  • ghastlycomicghastlycomic Posts: 2,531
    Thanks gang!
