fire and smoke... and eggs!
Hi all,
This concerns Smay's fabulous 'Fire & Smoke' prop collection. Until recently, this has worked perfectly but today, as I went to render an image including one of these props, instead of it rendering as a ball of flame, it renders as an orange egg. In other words, rather than the glorious flame effect I usually get, I get a featureless yellow or orange egg.
I've re-installed, checked it in Iray, 3delight and open GL, all the same. I haven't used it until now, since I also lost all the scripts I had put in the script menu. I doubt they are connected, but apart from updates to my nvidia GFX, nothing has changed in my set up that I could suggest as a cause.
Any ideas?
Thanks in advance,
G
  • scorpioscorpio Posts: 8,533
    They don't work in Iray sadly,
     I'm not having problems with them in 3DL, load a prop and apply a material and it renders as it should.
  • geoff6geoff6 Posts: 250
    Hi Scorpio,
    Unfortunately, it's not working in any render format.
    Thanks,
    G
  • srieschsriesch Posts: 4,243
    I'm unfamiliar with the product so I don't know how it is mapped, but is it possible you just bumped some surface parameter in your scene (changed a shader, tiling, opacity, etc)?  Does it work normally if you try using it in a new scene using the original object/shader from your content library instead?
    Hi sriesch,
    One of the first thigs I did was to start a new scene and just oad up the fir prop, unfortunately, it behaved the same. It's a mystery to me as it has worked perfectly before in Iray.
    Thanks,
    G
