MAG Arm 2 G2F for left arm has rigging problem.
Hi has anyone else encountered this? I'm fitting the geograft MAG Arm to my morphed G2F's left arm. As you can see in the screencap, the right arm fits fine, but the left arm is messed up. I have tried reinstalling the files, as well as adjusting the rigging to shape for the arm, but that doesn't work. Any ideas?
--MW
  • nemesis10nemesis10 Posts: 3,881
    edited October 2016
    Mine is rendering fine: a quick render... Is it possible that the arm isn't fitted to G2F and is fitted to the other arm?
    1453 x 1273 - 443K
    Post edited by nemesis10 on
  • Thanks for the response, nemesis10. I checked that the left MAG arm was indeed fit to G2F. I even downloaded the latest G2F and MAG arm files just in case and overwrote my current ones with them. No dice. And apparently the left MAG arm doesn't match the G2F skeleton even with a default G2F. See screencap. What the heck?!
    --MW
    673 x 752 - 60K
    May I have you select the left MAG arm's hidden properties in Parameters?
  • Is this what you're looking for?
    --MW
    1088 x 819 - 122K
    edited October 2016
    Close, show Hidden Items in Parameters and show Currently Used... you should see only the morphs for your character.  Next using the Edit men, zero the shape of your character and see if the arm returns to the proper shape; if it does, you have an errant morph trapped in your character.
    919 x 483 - 95K
