Content Library Search not working
LindaB
I have been away from DAZ Studio since shortly after the 4.9 release. Since the upgrade my Content Library search functions very poorly, it only show a very small fraction of what is actually in my library. For example, a search on 'robot' turns up the 'War Eagle' robot ignoring the Genesis robot and all the other robots. What can I do to fix this? It's pretty much worthless now. Thanks.
The Smart Content search is more sophisticated, you may want to use that then right-click and use the Show In sub-menu to jump to the Content Library. Alternatively, the Content Library pane search as two modes - database and filename - toggled by a button to the right of the text box, you may need to switch that to the option you aren't using.
I tried looking for robots in Smart Content, and had no luck. So I went back to the Content Library search and tried searching under both 'database' and 'filename', as you suggested and each search revealed different types of robot content, yet most of the robots don't turn up. The search worked great before the upgrade.
See my thread. It simply will not find Certain tems; whereas said items were seen in the past. It's like someone hacked a bug into our programs doh.
