Help With Adding Bones to Figure?
DakotaGrossman99DakotaGrossman99 Posts: 0
Hey guys, I'm Dakota, and I need help adding bones to my figure. I went to Window
  • Richard HaseltineRichard Haseltine Posts: 109,440
    Did you have any geometry imported into the Figure Setup pane? it doesn't, dirctly, work on an object in the viewport - for that you need to go to Edit>Object>Convert Prop to Figure, then you can add bones with the Joint Editor tool. To load an OBJ file into Figure Setup, right-click in the Geometry list area on the left and from the menu select Add Geometry
