Victoria 7 Make Up Orange?
So when I load up any of V7´s Make Up Options they just make the skin look orange? I´m using Iray as the render engine and DAZ Studio 4.9. How can I fix this issue?
Which make up options? Those with the Victoria 7 character? Which materials are you applying?
Please post a render showing the face, with and without make-up applied. Make sure you are not applying the Legacy settings.
So I´ve finally managed to do the renders:
so i just loaded up V7 HD in the right render
In the left render I applied one of her Make Up Options for Iray called "Victoria 7 Face 05 MAT"
That's certainly a noticeable efect, even to colour-blind me. I don't see such a pronounced diffrence if I load two copies of Victoria 7 HD and apply the face material to one of them, though that may be my colour vision and the lighting used (the default HDR lighting) - are you sure your copy of the base Victoria 7 (from which the make up preset comes) is current? I would suspect it is from before the bug fix that changed the way the SSS scattering colour worked - my copies are up-to-date, so I don't get the anomaly.
I looked at the Skin Materials that come with Victoria 7 and noticed there´s a "legacy" skin material for Iray so thats probably the old one ? and then there´s a normal "Iray Material" Is that the new one ? Or is it the other way around .. I´m confused
Yes, Legacy would be 4.8 and the other would be 4.9(+, we may hope).
