Tween Morphs for Genesis
Daz still hasn't released preteen shapes for Genesis, so I took a stab at filling the gap myself.
http://www.sharecg.com/v/65619/view/21/DAZ-Studio/Tween-Morphs-for-Genesis
Requires DS4.5 and Evolution morphs (also includes custom morph elements).
Nice,were do I install it?
They are looking really good! Thank you!
i've installed in My Library but i can't find the morph .Any hint?
Look under Parameters for..
Actor/Female/Real World/Tween Girl
Actor/Male/Real World/Tween Boy
Actor/Head/Female/Real World/Tween Girl Head
Actor/Head/Male/Real World/Tween Boy Head
Actor/Upper Body/Torso/Female/Real World/Tween Girl Flat
Actor/Upper Body/Torso/Female/Real World/Tween Girl Rounded
Maybe this helps:
http://www.daz3d.com/forums/discussion/518/P345/#161419
Edit: mjc1016 was two seconds faster - and better. :)
nope i'can't find anything in that path.
I tried to rescan unsuccessfully.Any ideas?
What version of DS are you running?
These look great! Thanks!
Dana
i'm running 4.5
Under DS 4.5, the main morphs do not show up under the Shaping tab, but if the product is installed properly, they will be available from the Parameters tab. If they aren't, check to make sure that the following folder exists:
My Library/data/DAZ 3D/Genesis/Base/Morphs/Murgatroyd/Tween
If it doesn't, you've got an installation problem. Find where the folder ended up (searching for tween should work) and move it to the right place.
In the parameters tab the morphs are not showed and i've checked the path and inside i've found your FBMTweenBoy.dsf file .The path is correct !!!
