Hi Res Mesh Conundrum
Long story behind this ... but I'd just sound stupid :)   so....
I have a G2F mesh saved as an obj in the default daz pose.  (Exported it to actually custom morph a clothing item)   After loosing a hard drive ... with that figure on it ... I've found some meshes that I'd like to recover BUT ... they're all high resolution.
Since there is no multi-resuloution morph support in DAZ .. what is the best way (or any way) to get this shape/mesh back onto a G2F figure?
  • It depends; one of the free modeling programs might be able to reduce the poly count enough that you could bring it back in via morph loader.
  • It will be impossible I would think to reduce the polygon count without breaking the geometry so it no longer is morph compatible.
  • It can be be done.
    First you would have to un-subdivide the mesh back to to it's original polygon count. That is the easy part.
    The problem is the vertex order will be changed so DS won't accept it as a morph. However, if the uv's haven't been changed they can be used to identify the vertices and transfer the data to your mesh.
    I know Maya can do this with their transfer attributes. There is a script for Blender called "Copy Vertex Order By UVs" that is intended to do the same thing but I don't know if it works.
    Mechaven said:
    It can be be done.
    It may sound easy, but unless I do it in the program that originally subdivided it in the first place, I seldom end up with anything useful...
    I've tried it and it seems to work...
  • mjc1016 said:
    Yeah, I guess I worded that badly. If the un-subdivide doesn't work properly there may be another way to get back to the original. If the script for Blender works, then I think it could all be done in Blender in a few additional steps. I may have to give it a try, and if it works I could let you know.
    It may work better since Blender now has OpenSubDiv support...I haven't tried it in a while.
