iRay: White Speckles
Hi guys,
I try to render the eyes but it got White Speckles like this video:
After 100% it is not like that but it still remain some noise in the eyes and do not look good...
Note that the White Speckles is more when I set Distant Light flux to high value, about 200000 and the White Speckles very clear, I would like to make it bright and it come with that.
Any tricks to render the eyes like this:
http://orig13.deviantart.net/69df/f/2015/135/3/7/tilted_rerender_by_second_circle-d8thv8u.jpg
Thank you
Post edited by ccthien83 on
High light levels with highly glossy surfaces can make it hard to resolve noise. Increasing the quality setting (which dictates how strict Iray is about defining convergence) may help, if you can't reduce the light or glossiness. Rendering to a large size and then downsampling will also reduce noise, by averaging it out. Both options will make for slower renders, of course.
Thank you Richard Haseltine, could you tell me how to Increasing the quality setting?
White noise is generally fireflies, which don't respond the same as unconverged pixels. As such, increasing any "quality" metric is not bound to have as much effect. You are best off rethinking the surfaces where the noise appears. Aspects of that surface, and the light you are using, are contriburing to the fireflies.
Check out the following PDF which addresses (on page 6) some steps you can take to deal with noise caused by fireflies.
http://irayrender.com/fileadmin/filemount/editor/PDF/iray_Performance_Tips_100511.pdf
From your video, while the affected surface(s) do seem to be white, they don't appear to be bright white, or overlit, but this may be the result of extreme tone mapping that could be causing the renderer to operate outside its use case specifications. To verify this, you might want to return the tone mapping settings to their defaults, and adjust lighting if it's out-of-whack.
Thank you Tobor, very clear explanation.
You may find this free script from MCasual very useful
http://www.daz3d.com/forums/discussion/91071/mcjdespeckle-pcwin-app-remove-fireflies-in-iray-new-daz-studio-frontend/p1
Great tool, thank you Mythmaker.
