Luxus not working with D|S 4.9?
in The Commons
Just bought luxus from fastgrab but no plugin is loadedand no render option.Does it work with 4.9?
It is working for me in DS 4.9.1; but I'm not sure about 4.9.2 because I haven't istalled the update yet.
Did you do install manager installation or Daz Connect? I did it through connect and it seems not everything works that way
It was installed with DIM a long time ago.
Also do you have LuxRender installed?
Yes, both through reality and stand alone. Both working. I'll try DIM
If you go to Help > About installed plugins does it show up there?
Is there anything in the log file about it?
Connect should never be used to install plug-ins.
I got it to work via DIM. And I agree, connect is a weird place to put plugins. I'm not sure I like it very much though. I'm used to Reality when rendering so I'm a bit overwhelmed...
Perhaps you should report it to customer service as it shouldn't even show in Connect.
