Morph Targets do not appear on Victoria 4.2 on daz studio 4.9
Hello.
If i load or pick the morph targets for Victoria 4.2 there happens nothing. The Morph targets arent loading.
Did i miss something or is that an Bug from 4.9 ?
Hello.
Did you (a) inject the morphs, and (b) go to the Parameters pane and dial them up?
I tried to inject an to pick a single morph targhet. Both doesnt work. I still have the old 4.5 version of Daz Studio but its an 32 bit version and will not work on my systhem.
I work with Windows 8.1 and i dont know if this is the issue.
What morph inject? Most of the injects are just to add the morph dial to the figure, they don't set anything.
How and where is V4 and the morphs installed?
What are the exact steps you take to load V4 and try to use the morphs?
I have installed the Elite and Basic Morph targets witzh the download manager. The Files are saved in my Document Private Folder.
I try to activate the Base and the Elite Morphs in the Windows but it doesnt work. The funny thing is that it worked all the Time but now not.
I try the Inject buttons and the single Morphs in the Windows. Only a few Morph Targets are taken. The Body and Head Morphs and the Vagina Grease. But i need the talking Morphs. But they do not appear.
There is a single file on the Download manager from Victoria 4.2. The Victoria Base Studio CF. But i dont know what this file is for.
It worked all the Time but as soon as i have installed a new Windows Version it dont worked anymore.
Daz Install Manager normally installs to the Public Documents folder in "My Daz 3D Library", not in the private folder. Do you have more than one content folder with a "Runtime\Libraries\!DAZ\Victoria 4" folder?
The Victoria 4.2 Base StudioCF has material presets for V4 that are optimized for Daz Studio. The main Victoria 4.2 Base zip has the figure itself.
I tried the older Version of DAZ3d studio and it both dont work.
Some Months ago i bought 2 females Meshes for Victoria 4,2. And the complete Morph Targets.
I think victoria 4.2 is no longer supported. Which Victoria has completely made Morphs targets with Faces and Talk Morphs ? As far as i have seen the newest Victiria is the 8. I would eed a new Female mesh for her and the Morph Targets.
So i hoped someone could give me a hint what modell would be the better for work on. either victoria 6 or 8. I must have the Morph targets.
Victoria 4 does work in the latest DAZ Studio all the generation 4 figure do. The gen 4's ExP morph system requires that all morphs be installed to the same library as the figures, due to this I prefer to install them to their own library that I name "DAZ Generation 4" to make it easy to find. Once morphs are installed they have to be initialized, DIM is suppose to do this automatically. The morphs may also be initiliazed from a batch file (on Windows at least) found in their library folder at; /Runtime/Libraries/!DAZ ; there is a separate batch file for Victoria and Michael.
How can i learn more about ExP location and how to install stuff outside the install manger.....haveing a hard time re wraping my mind aropund this
thanks
