Applying shader makes stripes
ckalan1ckalan1 Posts: 88
When I apply a shader, it makes stripes.
This happens on the objects I make, some of the ones I import, and sometimes it applies the shader perfectly.
It doesn't matter if it is colors or texture maps.
What am I doing wrong?
Any help will be appreciated.
Thanks,
Craig
  • PhilWPhilW Posts: 5,162
    You need to set the UV map of the object. This establishes the relationship between your map or texture (which are 2D) and your object (which is 3D - even if it is flat!). In your illustration, a number of points are all at the same point on the UV map, hence the same color is applied to them, and that is what is creating the stripes.
    There is a UV mapping tool in the vertex modeller (three icons at top right, it is the third one). For a simple shape like the one in your illustration, a planar mapping face on to the object will work fine and give you the results you need. UV mapping for complex organic shapes requires a much longer explanation!
  • ckalan1ckalan1 Posts: 88
    Thanks,
    I got it to work.
    Craig
    Great - I'm glad you got it sorted!
