Performance Issues
leo04
I am having performance issues. I start to render my scene and it seems to take forever, hour and hour and hours.
I have a pretty new PC
What do I need to do to enhance the processing speed? Any help would be appreciated.
Thanks.
Post edited by leo04 on
Are you rendering with iray or 3DL?
For iray, it looks like you might need an add-on video card. Do you have one? The 980ti is nice.
Look for an Nvidia with the most memory and number of CUDA cores that you can afford. Newegg is a good place to purchase from.
Rendering in Iray.
My PC specs:
Operating System
Windows 10 Pro 64-bit
CPU
Intel Core i7 5820K @ 3.30GHz 33 °C
Haswell-E/EP 22nm Technology
RAM
32.0GB Unknown @ 1066MHz (15-15-15-36)
Motherboard
MSI X99A SLI PLUS(MS-7885) (SOCKET 0) 32 °C
Graphics
HP W2072a (1600x900@60Hz)
HP S2031 (1600x900@60Hz)
4095MB NVIDIA GeForce GTX 980 (MSI) 32 °C
Storage
232GB Samsung SSD 850 EVO 250GB (SSD) 34 °C
1863GB TOSHIBA DT01ACA200 (SATA) 30 °C
Optical Drives
HL-DT-ST DVDRAM GH24NSC0
Audio
Realtek High Definition Audio
Thank you for your reply.
It is possible that your scene takes up more than the 4GB of the 980 so the render is being done by your CPU which usually takes a long time
You can look in the Daz log files to see what was used for the render: help - troubleshooting - view log file
Try to render a single figure at default settings as that should complete in seconds & will confirm the 980 is working
If it's a lack of GPU memory causing your problem then here are a couple of things that I find help
- Textures take up a lot of GPU memory, Many are 4000 x 4000 so depending on what you are rendering you can use photoshop or gimp to reduce the sizes - You can maybe remove normal/bump maps for areas of the scene that don't need as much detail.
- High level of Sub D that is not needed if the image is not showing a close up of that item.
It also depends on what is in your scene for example, lots of reflections, emmissive lighting and translucency/transparency will increate render times - sometimes dramatically.
