Strange lights colors
Hi guys, after I exported my animation I noticed that the light on the face of subject change colors (like a riflection). In the photo you can see the light i used (I just wanted a neutral light, I didnt put any filter to it).
Are there any options that I have to change to fix this?
thank u as usual :)
Looks like a character's specular map issue to me.
any idea how to solve it?
I attach the screen of the surface tab of the character
You need to make the screenshots with only one surface selected - at the moment you have two (or more) selected and they have different values for many of the parameters, hence the <?> entries.
sorry, I'm not very good at it! is this ok?
p.s. the material I used is:
No, you still have the whole thing selected - just click on Face in the list on the left, snce that is the problem area, though with luck someone will have the product and be able to offer you some advice.
Sorry, I hope this time is correct
Well, it looks as if there's a normal map plugged into Top Coat Bump, which might give odd effects. Also the Top Coat Thin Film value looks odd. if you set Top Coat weight to 0 does the odd effect go away?
