Water for the Recent Swimming Pool Freebie
Is there a way to put swimming pool water in the recent swimming pool freebie from the DAZ 3D store? It's being rendered in iRay, but also has a set of 3DL shaders.
  • FishtalesFishtales Posts: 6,215
    A plane or cube and add a water shader and size it to the interior of the pool. Or use Ocean Wide if you have it.
  • nonesuch00nonesuch00 Posts: 18,762
    edited September 2016
    OK, I was going to try the 1st so since you say that works I'll go for it. Thanks.
    Oops...it already has pool water...I just need to add a water shader. Oops, don't even need to add a shader...
    Post edited by nonesuch00 on
    I haven't opened it yet so I wasn't sure if it already had water or not. I thought it strange that you implied it didn't :)
    It's not that noticible until the render is almost done. Thanks very much.
