Props and figures lose position while parenting or fitting
I have a Genesis 1 that was receiving very well of all type of morphs maded in Hexagon, including wear and body morphs. But since few days all new props lose the position at the moment of parent or fit them to Genesis.
For example:
- I export the Genesis morphed or not to Hexagon.
- I model the object.
- I export it to DAZ and appears at the correct location.
- I change the prop to figure. All right.
- But I parent it to Genesis or Fit to Genesis, and at that moment the object goes up or down out of control. And don't let me change the location beeing attached to the character.
This happens too using the Transfer tool, using parts of body or body clones as support for these attachments. The same situation using the polygon faces tool for attach an object to the skin of the character.
The question is that this happens only since a few days but I can't understand why.
Javier
If Fit is off that suggests that your figure is not in a zero sate, but for parenting check that parent in Place is on - it's a check box at the bottom of the chnage aprent dialogue, or a menu item in the Sceen pane option menu if you are using drag-and-drop.
Correct... in part. ( Putting to zero was the same ). Was needed put Genesis to zero and unparent it from a null object used as relative axis for the character.
Thank you Richard. I forget that you can morph an attachment or a wear over a morphed character, but ALWAYS is needed that the first time that you put your objects in the scene to make the first FIT, the base character must be clean.
Javier
