GENERAL FREEBIE REQUESTS Part 2
Adding to Cart…
I might end up using that, but it's also shaggier than I want. I'm hoping for that early 1960s conservative cut. Since Joey Ducky has a "front shorter" morph, it might work though. I wishlisted it.
I am looking for a pair of glasses for my characters (of both sexes) and am unable to find any in the wardrobe section (I'm a new user). Although I'm looking for regular glasses (my main character needs to wear metal frames), there are a couple of characters who might benefit from a pair of sunglasses. Any help you might provide would be great. Thank you in advance.
Free: http://www.sharecg.com/v/35527/related/11/Poser/Glasses-for-V4-Smartprop
http://www.sharecg.com/v/80722/browse/21/DAZ-Studio/Nowadays-glasses-for-G2F
Plain but not wire frame: http://www.sharecg.com/v/69673/browse/21/DAZ-Studio/freeSPEX-Glasses-for-Genesis-DAZ-4.6
Paid: http://www.daz3d.com/steel-frame-specs
http://www.daz3d.com/spex-for-genesis (includes wire frame)
No kids4 fit, but free: http://freezone.thefantasiesattic.net/index.php?main_page=product_info&products_id=771
Thanks for suggesting it. That's Prae's Crew Cut Hair, which is very nice for what it is, but the neck is too shaggy for a 1960s look. For now, I'm going with a slightly longer hair that has a K4 fit, the short hair that comes with SAV's Spartacos.
Okay Will, I did a K4 fit for the Flat Top. Unfortunately I could not find a quick and easy way to just make a morph preset to apply the morph. So for my morph to work you will need to do some changes. I have included a text file which contains the steps for making the fit work in Studio. This fit is only for Kids morphs that change the shape of the head very little so if you have an alien shaped head this fit will not work.
Hope you can use this. It can be used for commerical or personnel renders. All other rights are reserved.
DollyGirl, that's so very great of you! I hate that I forgot to say I work in Poser, but I may try following your instructions in Daz and then export it.
Your fit looks perfect. Did you adjust in a modeling program? I've been playing with the X, Y, and Z, but either I don't have the knack or the shape for K4 is just too different.
Your welcome Will and thank you. What I ended up doing is using DAZ Studio and about 20 deformers to get the fit. So I did use scale to get close and then I used the deformers to pull and push the mesh to get it to fit. You are in luck in my journey to get the fit for DAZ I created the morph in Poser 2014 as well. See attached file. Not sure if it will work. I lost all of my content to a head crash and my Poser is a very unhappy camper. I think I will have to uninstall and then reinstall to get all of the stuff I need to make it happy again. So no guarantees that the Poser files will work but you are most welcome to try them.
DollyGirl, I put all four files into my Flat Top folder. Now your icon is present, and when I click it, something loads that's identified as "hair", but I can't see or select it. I tried a few things, like trying to find it with the posing camera, and had no luck.
I hope sorting out your crash goes well!
I need to start learning to use deformers sometime soon. :)
I did notice the hair comes in with the K4Fit at 1 and the Michael3Fit at 1. When I turn the K4Fit to 0, the hair appears as it normally does. As soon as I bump the K4Fit, it disappears.
I was afraid of that. Like I said my Poser is very unhappy at the moment. So I suggest, use Studio to export out the hair with the morph turned on and then import into Poser as a Morph target. Sorry about it not working. Yes deformers are an art in and of themselves. Think small.
Good advice. Thanks for doing this! I'll play with Daz tomorrow.
Anyone know of any beehive hair? Preferably free or cheap for Victoria 4.
http://www.sharecg.com/v/51022/gallery/11/Poser/Rand-Ponytail-Hair-for-V3-and-V4
http://www.sharecg.com/v/50660/gallery/11/Poser/Rand-Hair-02
http://www.sharecg.com/v/53461/related/11/Poser/Chris-C-Hair
http://www.sharecg.com/v/53462/gallery/11/Poser/Chris-C-Side-Part-Hair
http://www.sharecg.com/v/53463/gallery/11/Poser/Palamas-Hair-for-V3-and-V4
http://www.sharecg.com/v/64723/gallery/11/Poser/Louise-Hair-for-V4-and-V3
http://www.ShareCG.com/v/48072/view/11/Poser/Romulan-Princess-for-V3/V4 and http://www.sharecg.com/v/62579/gallery/11/Poser/New-Textures-for-Romulan-Princess-Hair
http://www.sharecg.com/v/61148/gallery/11/Poser/TPau-Hair-for-V3-and-V4
http://www.sharecg.com/v/50661/gallery/11/Poser/Nancy-Hedford-Hair
http://www.sharecg.com/v/48275/gallery/11/Poser/Lt.-Moreau-Hair
http://www.sharecg.com/v/47415/gallery/11/Poser/Blanche-Hair
http://www.sharecg.com/v/38665/gallery/11/Poser/Trio-Curl-Updo
http://www.sharecg.com/v/16192/gallery/11/Poser/Lovey-Hair-for-V3
http://www.sharecg.com/v/15881/gallery/11/Poser/V3-Lady-Jane
http://www.sharecg.com/v/10631/gallery/11/Poser/V3-Annabelle
http://www.sharecg.com/v/9932/gallery/11/Poser/Vulcan-Female-Hair
http://www.sharecg.com/v/9121/gallery/11/Poser/V3-J-Rand
http://www.sharecg.com/v/4635/gallery/11/Poser/V3-Chris-Hair
Thanks, Kerya! I can make one or two of those work, I'm sure.
I'm trying to cobble together a homecoming mum, but have run into a stumbling block right away - finding an actual mum. Anyone know of any?
Not free but not very expensive: https://www.renderosity.com/mod/bcs/the-nursery---chrysanthemum/95651
More expensive: https://www.cgtrader.com/3d-models/plant-tree/flower/xfrogplants-pompon-chrysanthemum
http://www.planit3d.com/source/poser/mambanegra1.html or with hexagon you can take this model apart and get a mum from it http://archive3d.net/?a=download&id=54be81b3
Free chrysanthemum
http://web.archive.org/web/20111213124251/http://toucan.web.infoseek.co.jp/3DCG/3ds/FlowerModelsE.html
I'm looking for an apple with a bite taken out of it. I see Exnem has a nice fruit set on that other site (which is on my wishlist for when it goes on sale) but I need just an apple with a bite out of it right now for something I'm working on. (It needs to be an apple for the symbolic element, any other fruit won't have the same effect.)
Not free but not too expensive here a couple that include obj format (which can be imported into DAZ)
http://www.turbosquid.com/3d-models/3d-crunched-apple-model/484851
http://www.turbosquid.com/3d-models/bite-mark-3d-c4d/668370
Thanks for those links, the second link is especially nice, but at that price for one, I would be better getting the whole set of Exnem fruit for $14. I might just bite the bullet and pay full price. I can probably wait 4-5 days before purchasing, maybe I'll get lucky and it will go on sale this weekend.
Does anyone have recommendations for a free caravan / camper / trailer with a) a bed and b) the ability to be hitched behind a car?
Things that are sort of what I'm looking for:
Martin62's Caravan is a vob file, which I can't read. T_T https://www.renderosity.com/mod/freestuff/caravan/59784
mph's Caravan with Tent is very simple and it could work, but it doesn't have a bed. https://www.renderosity.com/mod/freestuff/caravan/59784
Longhose's Tommycraft is just a shell. https://www.renderosity.com/mod/freestuff/caravan/59784
Birdman has some beautiful models on ShareCG, but none are rigged, and conversion to obj messes up the materials.
--MW
That pretty much covers the ones I know of...
How about this one free at ShareCG and includes Poser format as well as obj: http://www.sharecg.com/v/77888/browse/5/3d-model/1972-airstream ?
Also: http://www.sharecg.com/v/30662/related/5/3D-Model/Old-Camping-Trailer-w-vector-images
ETA: There is also this for only $2 if you are a PC+ member: http://www.daz3d.com/teardrop-camper
Thank you for the suggestions, Charlie. The first one that you linked to looked promising, but there was no bed. The second looks great, but it's just a hull. And sadly I am no longer a PC+ member. After trying and failing with several camper models, I should probably just purchase one at this point.
--MW
Meshbox has a $9.95 Airstream at ContentParadise and elsewhere that's been on my wishlist for a while.
Thanks will. That's the best camper value for my money, and I ended up getting it. The cool thing about the Meshbox Airstream is that it's completely modular, so you can rearrange the interior down to the individual pairs of curtains.
While I'm here, has anyone seen a decent cornfield of green ears of corn? [DeadCorn here is not what I'm looking for.] I want to do a corn maze, but will settle for just a row of corn that I can make people walk down. Free or inexpensive, please.
--NW
No field but...
http://www.sharecg.com/v/56101/gallery/21/DAZ-Studio/The-Corn-Stalk-For-DAZStudio
And it can be instanced.
Thanks mjc! With a little bit of work, I can make this serve.
--MW
