Axel for M5, now avilable {commercial}
13
  • Zev0Zev0 Posts: 7,122
    I will be making a version of my Vascularity product for M5/V5 UV's. But only when I finish one or two projects I am currently on. Hope other vendors start supporting them as well. Logically, it makes sense sticking with m4/v5 Uv's since they dominate the marketshare and usability factor. Making anything for M5/V5 only at this point is a guarantee'd financial hit compared to if developed on M4/V4. Unless the product supports Both UV sets, which means more development time, and a higher asking price. What we need to get the ball rolling is proper texture conversion support between the two.
  • RogerbeeRogerbee Posts: 4,460
    edited November 2012
    Hi, again,
    I worked out what the problem with the neck was, for some odd reason, the diffuse value for Skin Neck on all the body hair SSS textures was 1.0000000, I changed it to 0 and everything was fine.
    Problem solved! YAY! :)
    CHEERS!
    EDIT:
    The problem lay in the DUF file, I opened it in Notepad and looked for this line:
    "url" : "name://@selection#materials/2_SkinNeck:?diffuse_strength/value",
    "keys" : [ [ 0, 1 ] ]
    If you change that 1 to a 0 and save it, that fixes it.
    588 x 600 - 95K
    Post edited by Rogerbee on
    Thanks Pixel8ted for posting screenshots of how to fix this file. I was able to do it in a few minutes. REally apprecaite it.
    Sorry, yeah, screenshots would have helped. I can never remember how to do them!
    Male-M3dia should really fix the DUF and load an update as everybody will need it fixed.
    CHEERS!
  • yannich_ff4dab420dyannich_ff4dab420d Posts: 30
    I just bought Axel International to night for my Poser 9 runtime . Axel is really gorgeous but I can't us the morphs ( head,nipples ...) Do I have to buy something particular to access them ?
    I know why ... I have to upload a new Genesis M5 each time I want yo work with Poser . That's it , very simple . I am very sorry being so dumb
    edited December 2012
    CHEERS!
    Actually, this was submitted to QA a few days after the issue was found; however I don't know why it hasn't gotten out. I'll have to shoot QA an email tomorrow to see where this. It probably got buried under all the major releases.
    Post edited by Male-M3dia on
    Oh, right, I wasn't aware it was being dealt with.
    Glad you're on top of it anyway. It took a bit of head scratching to work out what was awry. It was only because David GB showed me how to fix an old version of the V4 Basicwear that I knew what to look for.
    I'll look out for an update all the same, just in case I ever need to reinstall him
    CHEERS!
    I have the same problem here . Can you tell me where is the .duf file to modify it . ( I'm on a Mac and work with Poser 9) Thank you
    442 x 427 - 165K
    Thank you very much, Rogerbee, I did it but had to modify 3 .duf files : Default , hairy with gens and hairy without gens . I hope you are paid for your tips :-)
    DUF's will always be in whichever Daz library you installed Genesis in. I only had the issue with the hairy one and only modded the one without gens as I'll never afford the M5 Pro Bundle or fancy posing him nude anyway. For me, M5 will always remain as Mattel intended!
    Being paid would be nice, but, much of what I fix can be down to a sheer fluke!
    CHEERS!
  • FusionLAFusionLA Posts: 249
    CHEERS!
    I just bought the Axel M5 a couple of days ago and also getting the duplicate IDs when loading any genesis character now.
    i thought it was the new DIM but after Uninstalling Axel it stopped, reinstalled and started again.
    Has then been updated yet, looking at this tread seems to have been an issue for awhile now?
    Also for Male-M3dia where do you get the underwear for the promo ads?, I been trying to find different male underwear.
    Thanks
    I'm not sure on that one, we used to get a notice if something had been updated and got download resets. Nothing came that I'm aware of. I fixed the duplicate ID manually. All I do know is that newer characters don't have the same issues, Ryuu is perfect.
    CHEERS!
    CHEERS!
    I was able to get the duplicate IDs fixed, but could not find the lines in the file to edit for the texture.
  • KharmaKharma Posts: 3,214
    AxelM5 is still not available through the DIM...could this be because these duplicate IDs are being corrected? I just bought him and hadn't d/l yet and now can't with DIM
    I was wondering the same thing. You can manually install Axel, but he's got one of my favorite skins, so I'm hoping he'll be available from DIM soon.
  • ForbiddenWhispersForbiddenWhispers Posts: 1,435
    We are sorry to hear the issues you are having with our Axel. QA is supposed to have the dup id fixed, as far as we know.
    I personally fixed the neck SSS issue and sent it to QA to be sorted. I think the best course of action is for you to put in support tickets with DAZ to remind them as we sent off the fixes months ago. Maybe if enough of you contact DAZ they'll take notice?
    I'll try them again myself. Hopefully this'll be resolved asap.
    Anna
  • Thadeus72Thadeus72 Posts: 415
    Anna
    thanks you for your help
    and axel is very nice character
    Anna
    Thanks Anna, I am impatient to use him but want to install all files through the DIM, so will wait until he is ready :)
    This is what to look for:
    “url” : “name://@selection#materials/2_SkinNeck:?diffuse_strength/value”,
    “keys” : [ [ 0, 1 ] ]
    Hope that helps
    CHEERS!
    I'm actually a bit suprised Daz hasn't fixed the installer yet, as I know this issue was reported to them before christmas, and the fix is known. Axel is a wonderful product and not having it available in DIM is a shame.
    I'm dubious about the DIM right now, I'll bypass it till you guys start raving about it!
    I'm happy with my Axel anyway, the HSS presets rock and I used them as a template for my own.
    CHEERS!
    Is the HSS texture issue a Poser only problem.
    I have not edited the files yet.
    Using Daz3d Studio 4.5, as long ass I use all HSS maps or all regular I don't seem to get the problem.
    Also thanks for the tip on the duplicate IDs that was a problem!
    You know what, I don't know,
    I just swapped the DUF I'd fixed without actually loading the original in DS. We should both really thank DavidGB, he was the one that taught me how to open files outside of DS.
    CHEERS!
    CHEERS!
    I'm actually liking the DIM, not all items are showing up yet for downloads.
    Uninstalling all the files I have already installed, was the biggest concern of mine.
    Having uninstallers for a lot of the items I had installed makes it easy to match up what DIM shows for downloads to know what to uninstall.
    Trying to figure out best way to merge all the free items and 3rd party store content into one library (that will be a pain to reinstall).
    But the time it will save me from having to download individual files and check for up dates is going to be worth it.
    The idea of uninstalling everything I already have and potentially not being able to get it back doesn't thrill me.
    I hope those of you that are waiting for Axel to be fixed and don't want to fix him themselves get an update in due course.
    CHEERS!
  • ErdehelErdehel Posts: 387
    Agreed. This is also the reason why I decided to reinstall everything (>1500 items). The only PITA is I already reinstalled all my items when I switched from Studio v3.x to Studio v4 and that was not so long ago, sigh...
    CHEERS!
    The fact that the developers of Axel submitted the fix months ago and it is still not available, does not send out a good message.
    I hear you, but, I would imagine they have a lot on their plate. It'll be done when it's done and this thread is here to help out anyone that doesn't fancy waiting.
    This world is full of too much instant gratification and I suppose I'm old school and can wait for things.
    CHEERS!
    Is there any news of Axel being ready through the DIM yet??? Curious to know why is taking sooooo long!!
