ToonyCam Pro
dakkuuan
I wasn't sure where to put this, so I chose here. Please move this if it's in the wrong place. I have ToonCam Basic, which was given out as a present during the holidays a few years back. When rendering with a transparent background, it renders a white haze around the character. Does Pro do this? Or does pro have settings that avoid this? I'd like to know before I purchase Pro, because it might very much change the way I render the images for my game. Thank you in advance, James.
I've noticed this not on transparent backgrounds, but on objects with transparency, notably hair. The toon camera tends to make the transparency a bit "fuzzy" or a bit more like translucent. It's easy to correct in Photoshop, though, especially if you're rendering masks.
I think I can live with that. Now just to wait for it to go on sale. I may have not tested the basic version with low enough shader rate
Actually setting the background setting in the camera itself to black solved the issue.
