Wet Hair Movement doesn't work
I purchased Wet Hair.  An Older product for David 3 but with fits all the way to M4.
None of the stying morphs work.  None of the movement dials show up unless I turn on Hidden Parameters in Poser Pro.
I am using Poser as the Promo says it will work in Poser.
It was installed using the DIM. I haven't had any problems with the DIM or DSON or any of that.
Can anyone think of a reason why the movement and styles parameters are useless and don't even show up.
Thank you for your time
  • One possibility is that the movement morphs are in a different bone (e.g. the main bone doesn't show the morphs but if you click on the neck bone, the morphs might be there) - don't know why but this is the way with several hairs I have.
  • Thank you for replying.  The neck bone lists that it's where the FIXES and Styles are supposed to be but they are blank. The plus opens to minuses thus meaning they are empty.
     They only show when I select hidden parameters and even then they still don't work!
    The Fixes and Styles are useless.  The movements don't work except for the chest hair.  I can move the hair from her chest and that is all.
  • mtl1mtl1 Posts: 1,508
    edited September 2016
    Hello, I have this product and deduced the problem: You have to hit the 00 Inject Morphs.pz2 for the morphs to appear work. Having said that, the morphs *are* still hidden despite running that INJ...
    Post edited by mtl1 on
  • Hey!  You're right.  It's located in the Shaders directory.  I injected the morphs you mentioned and now everything is working properly.  I can realize my vision.
    Thanks for stopping by and coming up with a solution.  It was strange.  I was wondering why I did have it working before and because I went to the directory called Color and Movement I never saw it.
    Thanks again.  Your help is greatly appreciated.
  • Quite a few of Valea's hairs from that period require that the morphs be injected.
