Looking for actual Cat/Fox ears for Males
ebonartgalleryebonartgallery Posts: 270
edited September 2016 in The Commons
So, what I need are a pair of anime-ish fox-like/Cat-like ears for a Genesis 2 or 3 Male. It could be a morph or a prop; doesn't much matter. Unlike normal ears, these are on top of the skull. The top-of-head 'ears in Fantasy Features for Genesis 3 Male(s) are utterly unacceptable - ears are thin poseable things, not thick immovable horn-like projections from the skull, and they need to poke up out of the hair as well - all you get with the FF is the abomination below.
When what I need to go for is something like
http://www.daz3d.com/forums/uploads/FileUpload/8f/9721f1b9a63b60f36ba70e29e69440.png
Post edited by ebonartgallery on
  • zombietaggerungzombietaggerung Posts: 3,856
    I would recommend Tandy Hair. The ears are a prop, seperate from the hair and will work on any figure as they load parented to the head. Here's what they look like on g2m and g3m, with just the default iray uber base thrown on them.
    1000 x 563 - 624K
    Post edited by zombietaggerung on
  • I would recommend Tandy Hair. The ears are a prop, seperate from the hair and will work on any figure as they load parented to the head. Here's what they look like on g2m and g3m, with just the default iray uber base thrown on them.
    SaveThat should do the trick; thank you :)
    You're quite welcome, I'm glad to help. I also forgot to mention, that I'm pretty sure these ears have some movement morphs in them. Don't know if that matters, but I figured I should mention it. smiley
    Well there's something to add to the wishlist that I didn't even know I wanted until now.
  • Doesn't it look odd to have two pairs of ears?  Normally ears would be made from the ears. :)
  • ebonartgalleryebonartgallery Posts: 270
    Well, the normal ears will be shrunk to nothing or made transparent and hidden by hair.
    Kinda of like this
    200 x 200 - 8K
  • Oso3DOso3D Posts: 15,090
    If you want ears attached roughly in the same place: http://www.daz3d.com/creature-creator-for-genesis-2-male-s
    If you want them higher set: http://www.daz3d.com/creature-creator-add-ons-for-genesis-2-male-s ; -- the ears are set higher and much more posable, but have fewer shaping options. Also, your skin choices are a lot more restricted to the options available for the ears.
