[Solved, PEBKAC] Genesis 3 Male anatomical elements has forgotten how to geo-graft?
SkirikiSkiriki Posts: 4,976
edited September 2016 in Technical Help (nuts n bolts)
Does anyone else have this problem: Load Genesis 3 Male, select him, load genitalia from anatomy, and it seems to attach, except when you inspect it closer, it did not attach properly (and make polygons underneath vanish), but has them visible? I tested this with 4.8 and 4.9Beta (most recent version), and it happens in both.
Edit: Solved, because today is a day when User ID=10T.
Post edited by Chohole on
  • Testing6790Testing6790 Posts: 1,091
    lol that looks exactly like what happens when you try to fit the wrong genital prop to the wrong figure.
    Are you sure you're using 3 on 3? I haven't gotten him, so I can't really test personally.
  • vwranglervwrangler Posts: 4,974
    Just wondering, are you seeing this when the characters are textured? I've only tried M7 himself and Aiden so far, but I'm not seeing that with either of them.
  • SkirikiSkiriki Posts: 4,976
    Yep, I loaded Genesis 3 Male, and loaded the attachment from his anatomy folder.
    Textured? Yep.
    763 x 345 - 367K
    688 x 663 - 598K
    edited November 2015
    WELL. That wasn't embarrassing at all.
    My active window was "Content Library"...
    ...while I also had "Geometry Editor" on, from my previous project where I had to do material surfaces to an object. Swapping to Universal mode made the "problem" go away.
    Perhaps I should not daz while sleep-deprived?
    669 x 742 - 34K
    Post edited by Skiriki on
  • Please tell me where to find the "anatomy" mentioned above from which you load genitalia.
    Do you have one of the adult male Pro Bundles (such as Michael 7 Pro)?
  • Ah I see, the OP referred to G3 male, so I failed to make the intuitive leap.  Thankyou.
    I am saving up my pennies for Pro packages.
    Keep an eye out, the Pro bundles are sometimes included in sale offers. Most of them have come up at least once in the last six months, and it's only a matter of time before they appear again.
    Note that there's only one Anatomical Element item — it's included in all the Pro bundles, and it fits any of the G3M characters.
