Sleeve Stuck to Hip - Weight Map Issue
3141592654
Good day everyone,
I am trying to apply the Princess of Asia dress (with long flowing sleves) for Genesis on a Genesis Three figure. It transfers well except that the sleeve is stuck to the hip. I have had a crash course in weight maps this afternoon and can see that specifically the tip of the sleeve is weight mapped to the thigh bend. I have tried many attempts, but have been unsuccessful at disconnecting the sleeve from the hip and moving it to somewhere else (probably wrist or hand). What am I missing?
Thank you
You need to select the arm bone and fill the weight map with a value of 1 - weight maps are normalised (the ttoal weighting must add up to 1) so if you add weight in one place it will take it away from others.
Thank you for the tip Richard ... I think that helps move me in the right direction.
