What causes this Render flaw?
I've gotten similar artifacts from time to time, and would like to know what causes it.
The light set up: 3-delight with 3 distant lights (key, fill, rim) and 1 spot. Spot set to "no shadows". Shadow Bias: 1.00
Render settings: Progressive; Bucket: 8, spiral; Max raytrace depth: 1; Shadow Samples: 32; Shading Rate: 0.20; 1236px x 2000px
Note that when rendered from a different camera angle, the artifact disappears. The flaw does not appear to follow the mesh geometry (G3F)
  • scorpioscorpio Posts: 8,533
    Try lowering your shadow bias
  • alkenalken Posts: 270
    This happens to me when depth of field is turned on and i'm test rendering.  Once I do the real render those anomalities go away. Hope this makes sense.
  • lexbairdlexbaird Posts: 168
    edited September 2016
    Alken, this is happening in my final render (actually, this is a spot render of the same flaw after I tried a few different settings, but it was showing in the final render.)
    Scorpio: I'll give it a try, but as I understand it, shadow bias flaws are caused by self-shadowing and look like the underlaying mesh. I dunno what would be casting on itself in that area. Is there a recommended setting? 1.00 is the default, and one try at it was set to .50.
    Post edited by lexbaird on
