Cloth Distoration When Appling Any Poses
in The Commons
Hello, All
I used marvelouse designer to build a cloth , then import it at Daz , then apply the Transfer untility ..
when tried to apply any Poses to Genesis. the cloth get distorted .
any ideas ?
I would be appreciated if some one list the steps to build a good designed cloth for DAZ using those software ( Marvelouse designer , Blinder, Zbursh )
You need to smooth the weight maps between the thighs and under the arms at the very least - although using a skirt template in the Transfer Utility may help. With loose-fitting clothing the automatic tansfer is never going to be more than a starting point.
