Iray lighting suggestions and tips
I was wondering if anyone might care to share some of their Iray lighting methods, as I've been experimenting for a very long time and am still not all that satisfied with the results. Do you only use an HDRI or a combination of scene lights and an HDRI at a lower strength? I've found a single spotlight at 50000-75000 luminence set to a rectangle at 50x50 or larger with a soft HDRI at .50 or lower seems to give predictable results without casting shadows everywhere.
I honestly don't know how some artists are able to get such interesting lighting in their scenes with this system where everything casts shadows and is geared towards being photorealistic. I've tried dozens of different methods and lighting combinations to try and get more of a fantasy or illustrated look and the only way I've been able to is with massive amounts of color correction and postwork.
Thanks in advance for any suggestions. Hopefully they'll help others as well!
  • AJ2112AJ2112 Posts: 1,417
    Truth is, lighting techniques vary with every scene, interior, exterior, materials, etc.....  I am certainly no expert, but a method I used to slowly understand lighting is, just practice using a plane and a cube, observe how light react to surface.  I would change cube materials, colors, etc...... a tedious process, but well worth the effort.
  • 3Diva3Diva Posts: 12,001
    I usually use an HDRI in combination with this product: http://www.daz3d.com/promo-style-catch-lights-for-iray
    I really enjoy the presets for that light set as it can warm or cool the image depending on which light set you apply to the scene.
    edited September 2016
    I do exactly what you suggested...I use two spots (for rim and key), an emissive plane (for fill) and a very low powered hdri to keep the shadows from being too dark and to add reflections.
    Laurie
    Post edited by AllenArt on
  • DustRiderDustRider Posts: 2,902
    Double post angry
    Post edited by DustRider on
    I try to light things like a photographer would, or how things are lit for professional videos or movie sets (as others have already noted).
    For example, how would a videographer of an archaeology documentary in Egypt set up for an interview on site in full sun light? They would no doubt have a translucent screen between the subject and the sun to create a diffuse light source. We can do the same in Iray by creating a large distant light or mesh light at the appropriate intensity, or use the Iray sun increasing the sun disk scale and/or decreasing ground shadow intensity. they would also have a diffuse reflector or two to help illuminate the dark areas, and further reduce shadow intensity. Again, we can mimic these techniques by making out own reflectors using proper shaders (controlling the intensity of the light reflected by making the shader material more/less reflective. Or we can add one or two low intensity fill lights in the same place we would add the reflectors, the larger the light, the more diffuse the shadows (spot lights can also work well for this to highlight the area of interest and not anything else).
    Focus on how you would light the same scene in the real world, and forget all ..... well actually most of the tricks you learned for 3Delight. A low intensity HDRI designed for genearal ambient light can be substituted for the reflectors/fill lights.
    Another trick that work well if your just want to use one light is the put your scene in a cube or cylinder, primitive set the scale to a negative number large enough to contain your scene, and give it a reflective surface. This will enable you to use a single light to light the scene (unless of course you have walls). The first image was done in Carrara using this method (only with Carrara I just inverted the normals on a cylinder) and full GI/ray tracing. It is lit with only one light, and no ambient light (for true realistic lighting effects). The second image is for comparison - same setup without the cylinder to reflect light. This can easily be done in Iray as well. However, it's probably much easier to use a good low intensity HDRI if you have one.
    Single light with cylinder for ambient lighting
    Single light without cylinder
  • kyoto kidkyoto kid Posts: 42,049
    ...with photometric lights, I feel like it's a lot of trial and error (which as a former lighting tech in theatre vexes me to no ends).   in 3DL I pretty much could judge how much intensity was needed even before rendering. Like stage lights the 3DL lights (as well as AoA's Advanced lights) had a set minimum and maximum setting.  One adjusted the lighting intensity by percentages to get the right mood for various scenes, just the like 3DL lights work. For different colours one just switched the "gel" (a coloured film that went in front of the light unit) not much different to changing he light colour in Daz. This is why in 3DL I found lighting to be pretty straightforward and rarely had an issue with it.
    Not so with photometric or emissive lights.  Now I need to deal with the complexities of luminous flux and temperature the first that never came up in theatrical lighting and the second was handled by which gel as used. Furthermore the scale for luminous flux seems to be open more ended, no more 40% or 60 %. On top of it  a photo metric spot is no longer just a spotlight but has different shapes now as well as something called beam exponent.  Crikey, if I had to calculate all that for the duration of a thee hour show, I'd be ready for more than a couple pints with the crew down at the pub when it was over.
    Currently I am working on some character proofs using Mec4D's ambient environment and a simple backdrop.  Adding a photometric spot at default value adds nothing to the scene (whereas 3DL lights are set to a default of 100%), so it becomes a process of pick a random value that is higher - test render, pick the next higher random value - test render, and on and on t until it looks the way it should.. When one doesn't have GPU that is capable of handling the render process, this can become a fairly drawn out operation.
    While I was no professional photographer, I could still hold my own OK pretty well.  I generally used three different film types/ISO settings: 64 (my favourite for outdoor photography because of the rich colour saturation), 100 and 200 (I wish Iray had "film quality" settings like LuxRender does) as those were the most common film ASAs (I also on occasion did shoot at 400 and even 800 but that was for hand held high speed action and available light photography at night). The only digital photography I have ever done is with a smartphone so any discussion relating to that is lost on me.
