Confused about Render Size
While learning DAZ i leave my render size set to the default (16:9) 1280x720. If I try to change this in Render settings to say ULTRA HD 3840x2160 the rendered image is cropped. or extremely zoomed in.  I also tried changing Dimensions on the camera settings with the same results: Is there something else i have to change?
  • Enable Show Aspect Frame in the Viewport option menu - the lined button in the top-right corner. That will show the area that will be rendered.
  • OK Rookie mistake. I was looking at the render preview and assumed it would show the entire image. Didnt realize there were scroll bars. But Thanks you!
