How to fit G3F cloth to G3M and vice versa?
How can I fit G3F cloth to G3M and vice versa? I tried with the "fit to" default option but it doesn't work properly
Thanks
  • fixmypcmikefixmypcmike Posts: 19,702
    What problem are you having?
  • The cloth from G3F doesn't fit correctly on G3M crying
  • Are you getting, and setting the options in, the AutoFit dialogue?
  • Could you describe how it doesn't fit correctly? Are you getting an ugly ridge in the middle of the chest (a known problem with no easy fix), or is the problem something else?
  • edited September 2016
    Yes
    Hi Murgatroyd. I want to fit a G3F hoodie on G3M. The arms doesn't fit well. It looks horrible!
    437 x 569 - 246K
    Post edited by Super cheese sandwich on
  • nonesuch00nonesuch00 Posts: 18,765
    I've had that cuff on the arm problems too...
  • Is it happening with just that item?
  • 3Diva3Diva Posts: 11,981
    You might try fitting a body suit to G3M (if you have one) and after putting on the G3F item have that item collide with the body suit rather than G3M. To do that have the item selected and then go to Parameters and have the item "fit to" the body suit rather than G3M. You can then make the body suit invisible.
    That trick has been working wonders for me.
