Genesis 3 Skin 'Tone'
Hello
Have been using genesis 2 base bodies (LEFT) in Smooth Shaded Drawstyle option for a while. But later on moved on to genesis 3 (RIGHT). And body skin looks white, while in youtube videos it's greyish. There was no similar 'glitch' on any forum to instruct form, so I reinstalled whole application with the content, but it's still there. Any help?
Thanks...
Your attachment isn't showing (if you repost please make sure you follow the rules on nudity http://www.daz3d.com/forums/discussion/3279/acceptable-ways-of-handling-nudity#latest ). Without seeing the image, the difference is probably down to the material settings - are you rendering in Iray (the default) or 3Delight?
Sorry. Seem file didn't get attacked...
Here's the pic
That's just the way the viewport handles some surface settings, principally those related to sub-surface scattering. The differences in settings/shaders may also affect the final render, but that is a separate issue.
Yes. Changing Subsurface strength in the surface pane has fixed the problem.
Thanks...
