It's possible to make this with zero post work?
It's possible to make this with zero post work? (Image attached)
  • nonesuch00nonesuch00 Posts: 18,773
    Seems like you should be able too just by hiding geometry.
  • Thanks for the quick answers but I'm looking for make it by myself. What is that thing about transmaps?
    Yes but I don't know how to mix the figures smoothly without using other programs
    Create a new surface after merging and on that surface a blended texture set.
    Thanks nonesuch00. There is a tutorial of that? I'm a novice with daz and even make some point lights It's a challange for me sad
    Thanks again
    Thanks again
    Not that I'm aware of.
    I recently created new surfaces for an 'experiment' I'm doing and basically you go into Tools Settings tab & select the Geometry Editor mode & in Geoemetry Editor there is the Surfaces tab at the top. Select the polygons you want in that surface, and then assign those polygons by right-click and assign to new surface & name it. You select multiple polygons for a surface by <CTL>-LMB for each polygon you want included in the new Surfaces group.
    Hopefully, a more experienced DAZ Studio user that can explain it more concisely than I can will come along.
