Michael 4 Power Loader
2getit2getit Posts: 0
When I loadup my victoria 4 it asks me to choose to put the ++ morphs onto it using the powerloader, however when I loadup the Michael 4 I dont get that option, so I have to dig to find the ++ Morphs injection and click the button to apply it, Did I install the Michael 4 right?
  • Richard HaseltineRichard Haseltine Posts: 109,174
    There was a separate installer for the Power Loader script - you need to run that. Otherwise it sounds as if it's working, so no you didn't do anything wrong other than missing an optional component. If need be, reset your order for Michael 4 from your Itemised Order History to get the PwrLdr installer.
  • JaderailJaderail Posts: 0
    Holding down Control (PC) will let you Set the Powerloader options at anytime if you ever need to change them. Just some FYI.
    Right, if you turned the dialogue off at some point that will get itt o display and you can then set options and, if you want, tell it to display in future. If the Michael 4 thumbnail in the library has a scroll icon in the top left corner that's the option you need, if not then my previous post applies.
  • 2getit2getit Posts: 0
    Thank you, I will check this out
