Green Screen option
Where is the green screen option in DS3D 4.9? I was looking for it in the viewport option in the right hand corner. I don't see it. Can someone provide a screen shot?
What are you trying to achieve? Which renderer are you using?
I would assume he wants to add some existing video/image into the 3D scene using green screen/chroma key.
One way is to just avoid rendering anything for the green screen area, that will be transparent if you save the image as a PNG and it's easy to add something else instead for background in GIMP or some other photo editing software, but it depends a little on what you need.
If you want a green background go to ENVIRONMENTS Pane(Tab) and set BACKGROUND to color you desire.
For some reason, Final Cut Pro X is sporadically rendering the Transparency produced in DS3D as opaque black. It plays nicer when it sees green. Thanks FirePro9, I will try that.
