Animation Conversion V4.2 to Genesis and Genesis 2 Female, not working
jcbunn
Can't get It to work.
I load victoria 4.2 (w/addons and without)( have to change its name to Victoria 4.2 )(cussing while im changing its name BTW)
Load Genesis 2 Base Female (from Gen 2 starter essentials)
select Vic 4.2, apply an animation ( run it once to set it in timeline) set the animation back to frame 0
Gen 2 female still in T pose
run the products V4 to Gen 2 script.
when finished G2F animation is only raising up its legs. :(
anyone got any ideals what im doing wrong. Thanks
Post edited by jcbunn on
The Fix, ...uninstall it from the smart content tab. ONLY use manual install and use the products icons in Content Library Tab.
It will not work if it is in the cloud folder and IT WILL try to use the cloud files so you must uninstall it
