Strange Bending Problem
Hi,
since today I have a strange bending problem. When I bend the stomach of Genesis 3 Males it really looks weird (see attached image please).
Does anyone have an idea what this is or what caused this?
I did not install new morphs or something. Strange.
Thanks,
  • Has something odd been ERCed to the bend? You can see the list of Sub Compenents in the Paraemter Settings dialogue, accessed via the gear icon on the slider, or you can review the whole thing in the Property.Hierarchy pane.
  • SF-DesignSF-Design Posts: 987
    edited August 2016
    Hi Richard,
    thanks for your comment.
    Let me check this, I will have a look.
    Something must be different there, in my other mapped library that I use to test and create stuff the problem does not happen. It only happens when loading g3males from my main library that is full of stuff :)
    Post edited by SF-Design on
    yeah found it. I recently installed a Yeti figure from Sixus. I removed the morphs to test and look, the bending problem is gone :)
    I need to tell the creator that his morphs cause such a problem.
    edited August 2016
    ahh seems he already was aware of this and provided an update, prob fixed now.
    thanks for the hint with the paramets tab, so I was able to locate it.
