DAZ Genesis Extension - Reallusion
Hi,
I was wondering if anyone could help me answer a question before I make another purchase from the Daz shop. Unfortunately my first purchase a couple of days ago didn't work out.
There is a DAZ Genesis Extension with the Facial Pipeline Character Pack from Reallusion which claims that you can easily bring in Genesis characters into iClone. Does anyone know if this will work with the Genesis version of Toon characters such as Sadie, Kimberley and Sam?
Thanks in Advance!
Yes it does
Thanks Sad.
I will go ahead and make the purchase then!
So far my experience buying Toon characters and trying to export them to iClone has been testing to say the least! Hopefully all goes well this time around!
Yes read your thread, Poser toon characters often a bit iffy, many I used had to be exported from Carrara with a bit of fiddling in the vertex room as use parented props.
Anything Genesis onwards and D|S should be ok though some not all geografts can vanish.
Just read on a Reallusion forum that there are no DUF files for importing Genesis 3 characters available yet. You wouldn't happen to know what Genesis characters (1,2,3) Sadie and Sam are would you? It just says 'Genesis' in the Compatible Figures part of the product. If I could drag and drop the DUF files straight into the Toon characters that would be great.
Sadie and Sam are for Genesis 1 (the original genesis).
Daz have a 30 days money back guarantee, so if some of things you have purchased that don't do what you want them to do and its less than 30 days since you bought them you can return them.
Great. Thanks scorpio and thanks Sad.
You guys helping out the Newbies are worth much more than your weight in gold!
