Saving your stuff in D4.5
Hera
Hello!
Since starting on 4.5 everytime when I'm saving a work DAZ has forgotten the name of the file and I have to name it as in save as. Very annoying since I might end up saving the wrong one and over writing what I was not supposed to over write. I want to save a file by simply pressing save and it should remember the name. Now how do I make this happening? I've been looking around in settings without any luck.
I don't believe that you can.
The idea is that you don't overwrite the existing file by making you use the Save As option instead of the Save one.
I don;t know if it has been changed in any future versions.
EDIT:
I am using DS 4.5.1.6, and if I load a scene and make changes, I can use the Save option (Ctrl+S), and it will overwrite the original .DUF file. If I use Save As, it needs a file name.
