LAMH -How do I get this to work in IRAY?
in The Commons
So I bought LAMH Gorilla, thinking the gorilla will look great in IRAY. DOH!
How do I get this to work?
JD
JD
Currently, you would need to export the hair as fibremesh to use it in Iray. There's an update to LAMH in the works but it hasn't been released yet.
There is this Video that shows how to get LAMH to work in iray to:
Pose and position your gorilla. Load the preset using the pane. Open the LAMH UI and activate the gorilla from the list of figures ( the hairs will switch from white to green). Click on the Blue "FIberHair" button. Make sure that the "load in studio" button is checked. Set the number of hairs you want (or accept the default) and then click on the affirmative button. Your hairs will show up on the gorilla in DS. Now you can render.
Kendall
