Genesis 2 Morphs
sueyasueya Posts: 847
I recently bought Genesis 2 Male Head and Body Morphs. I installed them and opened a scene which I started work on last week. The scene contained a Genesis 2 Male character which I had already posed. I wanted to use the morphs to alter the character's appearance. However I could not find them. Where do I find the morphs? Do I need to reload the Genesis 2 Male into the scene to activate the morphs?
  • BeeMKayBeeMKay Posts: 7,019
    Go to the Shaping tab. You will find the morphs slider there if you select the region you want to shape, for example head, feet, etc.
    However, if you already saved a scene that contains a character without the morphs, then it will remain like that. You could load the new genesis, and copy-pase the pose of the old to the new character.
  • IceDragonArtIceDragonArt Posts: 12,889
    Not sure why you couldn't just load your saved scene use the morphs to change the appearance and you should be good to go. You can then save it as a character preset so that if you want to use that shape again you don't have to start from scratch.
  • LindseyLindsey Posts: 2,009
    You need to refresh the morphs in the G2M character in your saved scene.  The way I do that is to select your saved G2M in the Scene tab.  Load a new base G2M.  You'll get a Chracter Loading Options screen.  Select "Apply this Character to the currently selected Figure(s)", click Accept   When the G2M is finished loading with all of your current installed morphs, undo the action with Ctrl-Z, to restore your original G2M character.  You should see the new morphs in the Parameter and/or Shaping tabs.
